Previous in Forum: Fastening torque specifications - Tensil load   Next in Forum: cups and plates made out of Arekanut plant leaf(Adike patte in kannada)
Tranter plate heat exchanger
07/22/2008 2:57 PM
We are using a Tranter Heat exchanger to heat up degreaser solution to de oil steel. The solution is alkaline based. What chemical can we use with an Clean in place system to remove dirt build up.
Re: Tranter plate heat exchanger
07/22/2008 3:34 PM
what kind of dirt,
alkaline removes protein based materials while acid removes minerals
