Previous in Forum: Hydro-Assist Fuel Cell   Next in Forum: Internal Alternator windings
rack and pinion
07/23/2008 7:02 AM
what would be the changes to the gears ratios if a 4.24final (72:17) rack and pinion installed
Gear Ratios:
* 1st Gear 33:10 = 3.300
* 2nd Gear 35:18 = 1.944
* 3rd Gear 34:26 = 1.308
* 4th Gear 30:29 = 1.034
* 5th Gear 31:37 = 0.836
* Final Drive 61:18 = 3.389
* Reverse Gear 17:10 x 36:20 = 3.600
* Speedometer Drive 13:22 = 0.591
(Golf mk3, 1997, "AAA" engine code, vr6 2.8l)
Re: rack and pinion
07/28/2008 10:44 PM
Ya! mean ring and pinion? Compared to what??
Good Answers: 123
Re: rack and pinion
07/28/2008 11:10 PM
Do you mean rotten pinion?
If you multiply the transmission gear ratio times the rear end (final drive) (rear axle) (ring and pinion) ratio, you will get the total gear ratio. Hope that helps.
Bob
Register to Reply 2 comments
