Previous in Forum: selection of gear motor torque and load   Next in Forum: Blackout
9 comments
Old LV MCC
07/24/2008 6:24 AM
I have old LV MCC 11/0.4kv supplied by 1 MVA transformer ,this MCC contain many feeders and motor starters which supply two administration building .I want to replace the MCC and to install emergency generator with automatic transfer switch to supply the necessary loads incase of any failure .
Please can some one show me the best way to do that
Re: old LV MCC
07/24/2008 6:35 AM
And your question is what, exactly?
Re: old LV MCC
07/24/2008 7:25 AM
my question is how to connect the necessary loads with the generator?
Re: old LV MCC
07/24/2008 8:37 AM
Then you need to discuss your requirements with your new MCC designer.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: old LV MCC
07/24/2008 6:37 AM
OK. I do a good range of previously-used MCCs. Nice cheap price. My agent in Vange will be in touch. <Sneeze, splutter>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 19
Re: Old LV MCC
07/24/2008 8:46 AM
Please furnish SLD(single Line Diagram) to enable to give you suggestions.
Ramesh,Freelance Electrical/automation Consultant
Re: Old LV MCC
07/24/2008 12:13 PM
While, technically speaking, this is not an extreme problem, but there is a lot detail necessary for a complete solution. There are a lot of possible suggestions that can be offered based on the limited information provided.
Does your current MCC automatically control all of its loads? It may be that replacing the existing MCC is not necessary if control can be added to it to limit load while being supplied by the generator.
Can the generator provided be large enough to supply the entire MCC without replacing it?
Is the MCC being replaced just to accommodate the installation of the ATS and generator? Will the new MCC be two separate units, one for critical and the other for non-critical load?
What kind of physical space limitations are you restricted to for the installation of your equipment?
There are possibly other aspects that may influence your installation, such as permitting and air pollution requirements for your generator.
If you can narrow things down a bit, you may get some usable information.
Re: Old LV MCC
07/25/2008 7:16 AM
The answer is rather simple if you only want to add the generator and replace the MCC. Remove the old MCC and install the new one with the same supply from your transformer. That accomplishes the new MCC.
Now, remove the feed from the transformer end and run the feed wires to the generator transfer switch and mount them on the terminals marked "load". Run new wires from the transformer to the transfer switch and mount them on the terminals marked "normal" or "utility" then run the wires from the generator to the transfer switch and mount them on the terminals marked "emergency".
That is the simple answer. There are other considerations that you will have to address, but what I have set forth above will accomplish the solution to the question as you have stated it.
All that is necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
Re: Old LV MCC
07/28/2008 5:56 AM
The best way if you don't want to burn the place, get in touch with the professionals on this job, then you learn from them.
i suggest you check this site: www.martsie.com
Re: Old LV MCC
08/18/2008 6:58 AM
During the preparation of the single line diagram,we found that most our load was AC split unit and two chillers,a lot of computers the following question were appeared:
  1. Did we need for power factor correction unit (low PF loads).
  2. Did we need for harmonic filters (harmonic generated loads PCs).
Register to Reply 9 comments
Anonymous Poster (2); kadex (1); Lendog (1); MARWANMASARWEH (2); ramvinod (1); Stinky Pete (1); The Commoner (1)
