Previous in Forum: Different types of hydraulic designs for fountain   Next in Forum: HVAC
Tips for building an underwater self controlled camera apparatus??
07/27/2008 12:17 PM
Hello, i am a Commercial diver for our family business and also dive for a prop seal specialist that services the Great Lakes area boats as well as around the world. i am interested in trying to build a self controlled camera apparatus that can go to depth. We already have the 'Splash Cam" setup that runs on a 150' cable. I am going to school for engineering and this is just more of a hobby for me than it is a crucial piece of machinery for the business. as i mentioned,we use the splash cam setup that is phenomenal for inspections and finding certain things before we descend, but the camera requires a diver to carry it around. Im not trying to put myself out of business..lol, but like i say this project is more of a hobby of mine. Main concepts i have to simplify into ideas: Has to carry 30 gal. pony bottle for buoyancy control with elec. purge and exhaust (not 30 gal drum.. size is about 3.5" dia 18"L Main Frame Elec. motors that will power small props for agility. this unit will have a cord running to it for the camera, any ideas or main concepts will help thank you!
Pathfinder Tags: underwater camera
Re: Tips for building an underwater self controlled camera apparatus??
07/27/2008 2:29 PM
have you tried www.makezine.com ?
Good Answers: 120
07/27/2008 11:07 PM
You can make a fluid filled camera. The fluid being a silicone fluid.
This will be noncompressible and non conducting and you will be able to get near neutral density. A solid state camera is best. The lens will have to be vented so as it changes focus you will not have a compression problem.
A fluid like this will differ from air in optical properties, but you should be able to accomodate easily.
This will allow for a lighter case because no great strength is needed, and in fact it should seal with a membrane to allow for the slight compression at depth.
Power will be either battery or tether power.
Tether power requires care in design. Either use high voltage at low current and include a DC to DC converter to run lights/lens/camera (one for each) or use thicker wire to keep the voltage drop tolerable. If you can design a small controller board that can be dealt with via serial commends = better, but more complex.
You can also use a TV remote control and chip to do this and couple the light to the camera via a light pipe made of multiple optical fibers.
Battery power makes it heavier and larger. It can still use the remote method above, and the batteries can tolerate the silicone fluid.
lithium or nickle metal hydride seems to be the choice, with lithium better at low current performance for longer periods and NiMh having higher currents. Lithium is more complex to charge and more costly, but seems to have the edge if you can design the chagring system
Lights should be LED as they can be immersed in the fluid, but check to make sure there is no air cavity that might crush.
Per Ardua Ad Astra
07/27/2008 11:22 PM
There already exist this type of camera used (and advertised in magazines for) the hydroelectric industry for inspecting penstocks and draft tubes. For fresh and salt water applications.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
07/28/2008 8:16 AM
Go to www.hcipub.com and in the click on the "Product Directory", search "camera" and you will find a list of underwater robot camera makers with links to there wesbites.
The kind I was going to build isn't built yet either.
07/28/2008 4:18 AM
Madness is all in the mind
Good Answers: 58
07/28/2008 5:08 AM
I suggest you contact an organization like the Woods Hole Oceanographic Institution. They are up on the latest commercial and custom made technologies. It is always lower cost to bootstrap off existing technologies than to develop new ones on your own. Once you establish contacts at an organization, you may want to travel there to explore concepts in greater detail (Cape Cod is lovely this time of year).
Register to Reply 6 comments
aurizon (1); bhankiii (1); CoronaCameraMan (2); GM1964 (1); welderman (1)
