Previous in Forum: LV MCCB price versus KA (short circuit rating)   Next in Forum: synchronising of 12 MW pumping station
Magnetic pick up
07/28/2008 4:39 AM
What is the use of a magnetic pick up and magnetic switch for a diesel generator?
Re: Magnetic pick up
07/28/2008 5:47 AM
Speed regulation?
Good Answers: 15
08/02/2008 1:32 PM
I don't know what a magnetic switch would be used for but "magnetic pick up" is the term most generator mfrs use for the inductive proximity sensor fitted to the flywheel housing to detect the starter gear teeth and this is then used as PWSlack suggests for speed regulation. Less advanced sets use a centrifugal governor which is usually much less accurate. The electronic governor will give >0.5 Hz no load to full load and a mechanical governor will likely be +2/-1 Hz (50 Hz sets)
Register to Reply 2 comments
