Previous in Forum: synchronising of 12 MW pumping station   Next in Forum: Current carrying capacity
d.g.set selction
07/28/2008 6:41 AM
we have total connected laod is 250hp,actual load is 120hp now we request you to kindly suggest the suitable d.g. set for us
Re: d.g.set selction
07/28/2008 10:58 PM
160 KVA will be good enough. Max motor you can start of 50HP having star-delta starter.
Good Answers: 19
07/28/2008 11:48 PM
In my opinion even 125 kVA set will suffice,provided the loads are smaller.
On a 160 kVA DG set you can easily start 80 hp motor on dol mode and 120 hp on star delta mode and not as mentioned.
Ramesh,Freelance Electrical/automation Consultant
07/29/2008 6:49 AM
the approximations given by respected members are quite fine for more selective choice all u need to check the power factor and the required kva.suppose u have power factor of 0.7 than for connected load of 120 hp the kva=120*.750/.7.also u need to specify the individual maximum load.
Anonymous Poster (1); jpsdhanny (1); ramvinod (1)
