Previous in Forum: 2009 Federal Budget Deficit   Next in Forum: CR4 Membership Growth
11 comments
windows frame
07/28/2008 12:00 PM
Good day
any body here have any idea about the windows frame we should use in chlorine environment area, as aluminum wont be compatible with chlorine?
thank you
An Engineer Creats the World that which never was. Theodore Van Karme
Re: windows frame
07/28/2008 9:40 PM
Vinyl clad?
Good Answers: 128
Re: windows frame
07/28/2008 11:03 PM
billybolbol,
As guest suggested, vinyl (polyvinylchloride). It is fairly resistant to attack by chlorine gas, but any exposed metal anywhere will be in trouble.
--JMM
Re: windows frame
07/28/2008 11:24 PM
Dear Billy
why cant you use the windows made out of wooden or concrete ?
thanks
wasantha.
Re: windows frame
07/29/2008 3:27 AM
It sounds as though there is a containment problem with the chlorine that is well overdue for fixing.....
Good Answers: 128
Re: windows frame
07/30/2008 9:51 AM
In my experience, it is very hard to keep chlorine from escaping into the environment. Therefore, design includes mitigating the harm it can cause to the structure and ensuring safety for those who work there. Even an occasional leak of chlorine, particularly in a humid environment, invites manor problems with corrosion.
--JMM
Re: windows frame
07/29/2008 5:42 AM
In all of the chlorine sheds I have had experience with, the window frames were all wood. If hardwood is used, mill a slot into it the same size as the glass and fit it into the slot. The best sealing medium is pitchblende or tar, as it is impervious to gaseous chlorine. I know this is rather "old hat" and low tech, but sometimes the 'old' methods are still the most reliable (and cheapest). By the way, use of a pvc paint or PVA can also help as either product is also unaffected by chlorine gas.
Regards,
Pete.
Having a farm is great provided you don't have to depend on it for a living.
Re: windows frame
07/29/2008 7:46 AM
What about Galvanized stainless steel,
or wrought iron coated
Re: windows frame
07/29/2008 5:57 PM
What's the point of galvanising stainless steel? In my experience stainless steel is not good around gaseous chlorine, but wrought iron is. Wrought Iron windows are a definite possibility, coated with a suitable antirust coating. Chlorine is a powerful oxidant, but in the case of wrought iron and chlorine only exposure it forms a hard oxide barrier and does not corrode further. However when exposed to moisture and air as well as chlorine, rusting can be accelerated, hence the need for good antirust coatings. Bare metals should be avoided for the same reasons, and I haven't seen much evidence that zinc, or galvanising, offers any better protection than any other. I would still go for the cheapest alternative - wood.
Cheers,
Pete.
Re: windows frame
07/30/2008 7:40 AM
thanks for your reply,
your answer is very useful, i rated as a good answer
but i wonder if i can use mild steel as wrought iron not really available currently,
also do u think i still need to galvanize it or coated by any how?
wood wont work for me as it is a high humid environment
thank you
thanks for every body here
Re: windows frame
07/30/2008 11:09 PM
Using mild steel should be OK. It works much the same as wrought iron, although you will definitely need to coat it with a coating that will not allow air penetration. I would suggest pvc or a two pack epoxy of some kind. So long as air cannot reach the MS it should be fine. Galvanising isn't recommended as chlorine will attack the zinc, unless it too is painted or coated. Coatings don't normally stick to galvanising as well as to MS so it probably isn't worth the extra effort. Powder coating of the MS can also work, so long as the thickness of the coating is greater than 80microns or less than 200microns. (Too thick coating introduces differential temperature cracking betwwen sides after exposure to weather and premature failure, unless the coating is very flexible)
Regards,
Pete.
Re: windows frame
07/30/2008 9:31 AM
Aluminum Titanium Alloy will work good
Register to Reply 11 comments
Anonymous Poster (4); BigPete (3); billybolbol (1); jmueller (2); PWSlack (1)
You might be interested in: Waveguide Pressure Windows, Windows, Infrared Windows
