Previous in Forum: can u solve this (difference between 50Hz & 60 Hz)   Next in Forum: US equipment issues (explosions) when used in Australia
question
07/29/2008 2:31 PM
hi all
what will happen if we run generator and its output leads ''A,B,C'' are connected together ''shorted''?
the voltage regulator of this generator is getting supply from these leads.
many thanks
Good Answers: 21
Re: question
07/29/2008 4:25 PM
You will hear the boom.
See the fire.
Smell the smoke.
Momentarily the regulator should attempt to increase voltage in response to the fault conditions.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
India - Member - New Member
Re: question
07/29/2008 11:01 PM
Another view;;;
If there is no excitation voltage at the regulator output nothing will happen,
If you are able to contorl the voltage carefully , you can induce full load current.This mehtod used to remove moisture.
Regards,
Hareesha
Nothing is impossible, Impossible is nothing
Re: question
07/30/2008 3:48 AM
All the previous answers are valid. Thing is, the residual magnetism by itself can generate such a high voltage causing a damaging current to the generator ( even without the AVR kicking in). If you can regulate the voltage somehow to get a low or zero voltage before shorting the phases then the drying thing is possible as you gradually increase the voltage while monitoring the currents. With an AVR this is not desirable. The automatic function will try to raise the voltage to set(operating) value. If it has overexcitation protection it MIGHT trip before it goes BOOM.
Curiosity has its reasons for existence - Albert Einstein
hara143 (1); jjnyongesa (1); Switchman (1)
