Previous in Forum: can u solve this(alternator excitor rating)   Next in Forum: question
can u solve this (difference between 50Hz & 60 Hz)
07/29/2008 1:38 PM
hi,
will some one tell me the advantages and disadvantages of 50 and 60 Hz of frequency.
Good Answers: 97
Re: can u solve this (difference between 50Hz & 60 Hz)
07/29/2008 1:44 PM
This is easy - It is exactly 10Hz.
Good Answers: 73
07/29/2008 4:26 PM
Advantages of 60Hz over 50Hz:
  • less noticeable flicker in some kinds of lighting
  • slightly smaller inductors and capacitors
  • higher RPM for a given motor design
Advantages of 50Hz over 60Hz
  • timing precision is a little easier
  • because it is nearby (perhaps).....
  • calculations all have a multiple of 5 in the answer....(easier on the slide ruler)
I'm reaching as far as I can....but this is really something of historical perspective. I can't say that I know what the historians were thinking, but I think there was some concern given to making a reliable clock in the thought process.
To paraphrase (if not quote) Mark Twain, "History does not repeat itself, but sometimes it rhymes".
Good Answers: 18
07/30/2008 9:01 AM
Well, if you're in a country that has 50 Hz power it's an advantage to use appliances that are designed for 50 Hz, and it's a disadvantage to use appliances designed for 60 Hz.
If you're in a country that has 60 Hz power it's an advantage to use appliances that are designed for 60 Hz, and it's a disadvantage to use appliances designed for 50 Hz.
08/01/2008 10:12 AM
There isn't a global standard for low-voltage power supply. As national networks were developed they did so largely on the basis of not knowing or caring what the other countries were doing, to a greater extent, so the frequency difference is historical, as is the voltage difference.
Even where countries use the same frequency, e.g. France and Britain, there is always a phase difference between them, making conversion to DC and reconversion back to AC a requirement for inter-country power trading and load balancing arrangements.
The railways of Switzerland used 162/3Hz at one time....
08/01/2008 10:15 AM
P.S. Note that many power supply inlets for portable electronic equipment, such as some laptop computers, are arranged for multi-voltage, multi-frequency inlet, in an effort to overcome the problem of not knowing exactly where in the World its power will be drawn from.
Bill (1); Hendrik (1); NotUrOrdinaryJoe (1); PWSlack (2)
