We recently purchased a 4 fan, 37,000 BTU Unit Cooler. X-plosion Proof Class 1, Div, 1 Group C&D etc, etc...The unit was to be operated with Propylene Glycol at 30%-35% with a supply side temp of -3 / -4C (-25/-27F). We have a room that is appx 12' w x 38' L x 9' h, new construction, very well insulated. There is a 1.5 hp pump that circulates ethanol and additives in a small batch tank, other than that, no other heat gain. We intended to maintain a room temp of 13C (55.5F)
After a significant lead time (several months) a unit which utilizes refrigerant arrived.
Question: Can the unit be modified / piped with a new header to a glycol supply line and achieve something remotely close to our temp requirements? We will ultimately order a new coil, but looking for something in the interim... this part of the project is currently on hold. Any thoughts?
First thought is to pipe it up and see what happens.
Thanks
PS Coil size is 3/8" copper with aluminum fins
