Previous in Forum: future mech engineer   Next in Forum: heat and mass transfer?
about Magnet
07/30/2008 7:51 AM
i want to know a magnet for seprate iron from upto 500mesh powder of quartz mineral
please suggest a industriel machine for this purpose
Ashok Kumawat
Pathfinder Tags: magnet
Re: about Magnet
07/30/2008 9:30 AM
<sigh>
What sort of separation rate is intended?
How is the mixture to be agitated?
What method of removal of the separated iron is intended, i.e. would an electromagnet be better than a fixed magned?
In what sort of equipment, in what sort of environment, is this magnet intedned to operate?
Re: about Magnet
07/31/2008 11:17 AM
dear
thanks for your commment
i want to put magnet in between machine called Hammer mill
flow of material is regular
the iron contamination is wear and tear of machine
we want a permanant type magnet
please suggest
process is dry
Good Answers: 15
Re: about Magnet
07/30/2008 11:56 PM
2 conveyor belts?
the product on the bottom one, a electro magnet above with the top conveyor running against its surface, the magnets pull the iron from the material and are transported along the magnetic surface to a seperate conveyor past where the quartz is off-fed?
Something like this?
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Re: about Magnet
07/31/2008 6:11 AM
Manufacturer that comes to mind: Eriez
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 18
Re: about Magnet
07/31/2008 6:36 PM
GA. When I worked in coal handling and processing, we used Eriez magnets on a hammermill for tramp iron removal.
agua_doc (1); gurumetalsbwrglobe (1); PWSlack (1); sidevalveguru (1); Snaketails (1)
