Previous in Forum: How to Generate Pulse Width Modulation?   Next in Forum: Negative Voltage
Rotor Lock (VSD-Cegelec)
07/31/2008 2:04 AM
Hye All,
i encounter a new problem with my VSD motor. Really appreaciate if you guys can give me some idea to troubleshoot this problem. the cronology as below:
We shutdown the motor (29/07/2008 @ 1100) due to sound abnormal. the operation suspect the sound coming from the bearing. once the mechanical settled inspected the bearing, operation request to run the motor(solo run). unfortunately, when the motor start, the RPM start to increase. so thus the current. its normal for the current to increase since it was starting current. but then when to motor reached 50rpm, then it starts to reduce the rpm but the current continue increase until the motor trip. when obserse at site, once the motor tripped the shaft (with coupling hub) stop immediately like something hold the rotor.i did check the exciter bridge, machine bridge and also network bridge, but everything in good condition. from the mechanical opinion the bearing still ok since the shaft can be manually rotate. below are the detail of the motor:
rated current 800A
rated voltage 2.2kV
exciter rated voltage 415V
during the problem the exciter current show at 240A.
really need your help. if need more information please let me know.
-tom-
Re: Rotor Lock (VSD-Cegelec)
07/31/2008 1:09 PM
Are you talking about a 3 phase synchronous or a large DC motor? It also sounds like you uncoupled the motor from it's load to test it. You mentioned that the field current went up to 240A, which seems high for the field. What is the rated field current (on the motor nameplate)? Have you done any resistance (high-pot) tests with the motor?
From the description of the speed problem, it could be a problem with the VSD control.
I would suspest the bearing as you previoulsy may have, but you said that the shaft can still be rotated by hand.
It is an interesting problem. I'm sorry that I can't provide any better input than this.
