I have tried to use 2 arbitrary function generators to generate a sine and triangular waves respectively. Can get a pulse width modulation (pwm) after input both waves to a comparator.
Used 2 XR-2206 function generator chips to generate a similar sine and triangular waves as that of the arbitrary function generators.
However, the output pwm produced is not the same as those produced from those generated from the arbitrary function generators.
Any idea why is it so? Did I miss out anything?
Thanks.
