Previous in Forum: exothermic and indothermic reaction   Next in Forum: Please suggest submersible Pump MOC for dewatering Lignite mine water
Glue for Staple pin
08/04/2008 1:45 PM
Hi,
I am looking for a adhesive / glue which is used to bond staple pins (all kinds) during production process. An ideal glue should be less viscous (thin), transparent liquid. It should provide a very strong bond at a temerature around 50 to 60 degrees centrigrade. It should be corrosion resistant. It should also provide a liqour / shiny finish.
More over staple pins should not seperate from each other under ordinary circumstances for very long period. Could some one guide me how could I find it? How can I classify it?
Good Answers: 123
Re: Glue for Staple pin
08/04/2008 6:04 PM
There is a company in the USA that has more types of glue than I can list. Try www.devcon.com Their engineers will help more than I could. Good luck.
Bob
08/05/2008 2:35 AM
An ordinary clear varnish for wood should do the job. use straight from the can or if you need to thin it then use lacquer thinners or even acetone- they will drop the viscosity quickly and keep up the solids. after a short air drying to get rid of the solvent drying can be apeeded up by baking -colour should not be a problem so any yellowing from baking should nbot be a problem.
Any clear lacquer will do the job but the domestiic varnish will give the highest solids and so strongest film it really just a supporting skin that you need.
You can always tell the pioneers - they are the ones with arrows in their backs.
08/05/2008 2:15 PM
Cyanoacrilate (crazy glue) might work. The suggestion to contact devcon is good. You might also contact 3M (Minnesota Mining and Manufacturing) as they have some exotic fastening compounds also.
Ralph
I used to couldn't spell engineer and now I are one!
11/12/2019 12:13 AM
HI, I am looking for same purpose for my own manufacturing process. Did you find any glue and let me know the name and supplier, and cost for sample to deliver to Sri Lanka
Register to Reply 4 comments
bob c (1); ERENGINEERING (1); hazman (1); sisira1 (1)
