Previous in Forum: Please suggest submersible Pump MOC for dewatering Lignite mine water   Next in Forum: Looking for supplier of large quantities [100kg +]
units
08/04/2008 2:06 PM
we are using silicon sealant tube as rubber gasket on that i found one unit
30z=85gm
what is this z
thoughts becomes things.
Pathfinder Tags: Units
Re: units
08/04/2008 4:12 PM
What is meant is:
3 Ounces (oz) = 85 Grams (gm)
It seems you have mistaken an 'O' for a zero
Re: units
08/05/2008 8:05 AM
1 ounce = 28.3495231 grams
3ounce = 85.0485693 grams
Basically u it is 3 ounce not 30z
An Engineer Creats the World that which never was. Theodore Van Karme
Re: units
08/05/2008 12:08 PM
normally where this unit get used
for which material?
Good Answers: 37
Re: units
08/05/2008 12:30 PM
"Ounces" are units in the Traditional British, or inch-based system* of measurement. It is still used in the USA, Myanmar, and I believe Liberia. Your best choice is to ignore it entirely. Ounces may refer to weight [not mass, usually] or to force, or to fluid volume, among other possibilities. As a measure of weight, an ounce is 1/16th of a pound (a pound at 1g is equal to 453.5924 grams). There are also several KINDS of ounces and pounds, not equal to each other, used for weighing some intrinsically valuable materials. Thus, to avoid splitting headaches, stick to the metric system.*
*"System" is a misnomer with regard to Traditional British units, as there is nothing systematic about it! It is a hodgepodge, a compilation, a compendium, an aggregate, but certainly NOT a system.
" Ignorance and arrogance have more in common than their last four letters. "
Re: units
08/25/2008 3:31 AM
z = ounce
British Standard, like pounds.
Anonymous Poster (1); billybolbol (1); R.Radhakrishnan (1); Ron (1); sandeep lokhande (1)
