Previous in Forum: backyard pond with leak   Next in Forum: "Total Solar Eclipse..." links to video from Iraq!
11 comments
External Combustion and Waste Heat Engine Prototypes
08/04/2008 10:09 PM
Two new prototype engines that have just been brought to my attention.
Cyclone External Combustion Engine
Cyclone's Green Revolution Engine represents true "thinking outside the box." This is because it is not a new variation of the internal combustion engine, but rather, a highly advanced External Combustion Engine. Unlike IC engines, the Cyclone engine uses an external combustion chamber to heat a separate working fluid, de-ionized water, which expands to create mechanical energy by moving pistons or a turbine. Since the combustion is external to the mechanism, the Cyclone external combustion engine can run on any fuel, liquid or gaseous. Ethanol, diesel, gasoline, biomass: anything from municipal trash and agricultural waste to traditional fossil fuels can power the Green Revolution Engine, individually, or in combination. Initial tests of the engine used fuels derived from orange peels, palm oil, cottonseed oil, and chicken fat -- none of which are impacted by cartels, hostile governments or dwindling reserves.
http://engineeringtv.com/blogs/etv/archive/2008/06/03/cyclone-external-combustion-engine.aspx
Cyclone Waste Heat Engine
Cyclone Waste Heat Engine The Cyclone Waste Heat Engine (WHE)is a self-starting engine that operates in a low pressure, low temperature range. This feature allows the engine to run on waste heat emanating from an external source, such as the exhaust from an internal (or external) combustion engine, or the direct burning of biomass (i.e., processing garbage into methane would not be required). The Waste Heat Engine is also designed to run efficiently on solar heat without the installation of costly photovoltaic panels. Commercial applications for the engine include boosting the power and efficiency of large gasoline or diesel-powered generators. When installed to the exhaust system of an engine that can generate over 1000 degrees of heat, the WHE could materially increase overall horsepower and reduce fuel consumption. Additionally, once installed, the Waste Heat Engine could serve as a stand-by generator should the primary system shut down. Another major commercial application includes solar-power generators for homes or businesses. By attaching inexpensive panels to a roof, enough heat can be produced to run the Waste Heat Engine. Cyclone believes that such a system could be installed at a price of approximately 20% of the cost of comparable photovoltaic panel systems, while also providing home owners with a back-up power supply. Excess electricity could be directed back to the power grid for electrical power credits.
http://engineeringtv.com/blogs/etv/archive/2008/06/02/cyclone-waste-heat-engine.aspx
Both appear promising at first glance and worthy of a look. It's this sort of out-of-the-box thinking and development that allows us to move ahead technologically, not some rubbish pseudoscience. I doubt you will be running your cars on them, but the specialty fixed installation and third world applications I can think of offer promise.
What do people think?
Good Answers: 101
Re: External Combustion and Waste Heat Engine Prototypes
08/05/2008 11:09 PM
Looks like a brilliant idea. As noted, the chief advantage of an external combustion engine over an ICE is its ability to use any heat source as an energy source, including waste heat energy. Using heat to vaporize water to generate mechanical force, then using the waste heat energy from the condensing steam to pre-heat the incoming cooling water to reduce the energy required to vaporize it will give very high energy efficiency. And it's certainly a far more intelligent way to utilize water to power a vehicle than using the onboard electrolysis of water to generate "Brown's gas" to power a car.
08/06/2008 12:02 AM
This reminds me of the advantages of a sterling engine. However, not much love for the sterling outside of hobbyist groups.
I'd love to see the sterling or these cyclone engines take over for electric generation. A car's alternator sucks horse power to generate electricity for the car. Using the heat of the exhaust or at the radiator or the manifold or the ... the waste heat could be turned into electricity via this cyclone or a sterling engine.
How about nuclear waste as your heat source?
Gabe
http://blogs.ControlTheoryPro.com
Aerospace Systems Engineer; http://blogs.ControlTheoryPro.com
Good Answers: 247
08/06/2008 12:59 AM
I'd love to believe that this engine will do well, but I find the website lack of data disturbing. This engine has been around for a long time, and they have loads of pictures of it apparently powering things including a 10 kW generator, but no performance data whatsoever. If I go to Honda or Kubota or Hatz, I can easily get Brake Specific Fuel Consumption data. But the FAQs on this website just dance around the real data and offer nothing with which the engine might be evaluated. Some of the information in the FAQs is completely silly.
For example:
  • 5. What kind of standardized/known type of tests proves the low pollution performances? Are there some figures?
    External combustion is a known quantity as being a known clean alternative to the internal combustion engine. This is common knowledge and can be easily verified. For example, a space heater that is run indoors as a gas or diesel generator will cause death. See the C.A.R.B (California Air Quality Board) and Federal HAPs Data.
The writing is awful, but also the logic is bizarre. Obviously, external combustion space heaters are unsafe for indoor use. External combustion is not free of deadly CO, nor is it necessarily free of unburned hydrocarbons and oxides of nitrogen. Coal fired power plants are external combustion but emit all sorts of noxious stuff. The question is what type of tests have been run. The answer is "none" evidently, because nothing said there gives emission data.
Another example:
  • 3. Are some available testing data related to the engine behavior under full duty and partial/low duties?
    Engines have been built and run for periods of time and data has been recorded. The theories are calculable and proven knowledge. We are simply putting the engines into a compact mechanical package.
This doesn't come close to answering the question. It reads like Schoell is a politician, not an engineer.
No data is presented on the most central issues: How much fuel goes in? How much power comes out? Nowhere on the site is this essential info available.
This seems to be perpetually at the same stage of development, and the wording and lack of info seems slippery to me. After all these years where is the performance data? The only test data I have heard about but not seen is that the engine tested at 23% efficient, not the 30% or so that Schoell claims in the Design News video.
It will be interesting to see if anything comes of this, but why aren't they producing a real running prototype with data?
08/06/2008 9:15 AM
ken is spot on, everywhere I went mubo jumbo
"Super-Critical Fluid - Pressures in the range of 3200 psi with temperatures of about 1200°F cause super-critical vapor to act as a fluid. Maintaining the super-critical pressure, in the centrifuge process, eliminates the turbulence, backpressure events, and heat spikes that can occur during other less efficient types of super-critical processes. At these higher temperatures and pressures, the super-critical 'fluid' carries more heat energy to the motor it powers. The Cyclone Engine is a piston engine with a special valve mechanism allowing it to operate at fluid pressures, thereby gaining multi- advantages; greater simplicity, reliability and enhanced power."
Super criticlal vapor acts as a fluid!! What do you think the maintenance will be on a 3200 psi pump. I don't care what he said, its a boiler, as soon as you have anything above its critical pressure, its a vapor, so its a boiler, running a steam piston engine, with waste heat recovery.
Efficency, you don't get the whole picture because, you have to put energy into the water before you can use it! deionized water, oh yeah, its a boiler, you need boiler feed water!
08/06/2008 9:31 AM
Right you are, Ken, which is why I voted you a GA on this reply. I wonder how well it runs on snake oil?
Good Answers: 93
08/06/2008 5:39 PM
GA from my seat as well. Thanks very much for reading the sites and reporting to us others. In the Sustainable Energy Blog and other member discussions External Combustion Engines have been much discussed. We have come round to Sterling Engines very often, and one of the members exposed us to a list of companies and models. I imagine starting a company named The Mythical Sterling Company. Apparently they are right expensive and specialized at this time. There is conflict between Internal Combustion Engines and External Combustion Engines that will tip more towards External Combustion Engines than was the case during my lifetime, and for another 50 years before. For farmers with a multiplicity of possible fuels the right priced Sterling offers energy cost savings on its face, though I understand ECEs as electric generator power, and for the local farms of NC around where I live, electricity may not be the main energy cost to reduce. Of course your ideal ECE would Solar run your tractor, I suppose. Kockums is the name of a Swedish company I remember that makes Sterlings for Submarines. There was another of interest to us that I can't remember the name of. Of CR-4, I typically regard Sterling Stan as one expert to query, though as much archive writing on the subject you could just look up his posts really. For renewable and alternate fuels the ECEs are extremely important to core integrate into a complicated set of needs and resources that vary around the planet. It is a subject worthy of thought and effort. I believe the Cyclone Engine was the name of a very important Radial aircraft engine. To be worthy of the engine name Cyclone, whatever engine you produce ought not insult the name, for it was a very good and important engine.
You don't get wise because you got old, you get old because you were wise.
08/08/2008 5:43 AM
I'm probably nitpicking, his video often returns to nitrous oxide n2o as a combustion byproduct. I thought (and I could be wrong as I have been before)no no2 were the primary nitrogen-based exhaust emissions, and nitrous oxide is commonly referred to as laughing gas.
However the point has been rendered mute. I've discovered the existence of a engine that will solve the worlds problems, a vaporization engine. It is multi-fuel compatible, and has the capability to produce no net carbon emissions. This capability is derived from its ability to be fired on things like finely powdered coal, substitute manure and you have a perfect engine. No net carbon emissions, fuel produced from a renewable source, in this case BS.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
08/06/2008 9:09 AM
Wow Jack,
There was a time when these external combustion engines were used every where, even is an automobile. We just called them steam engines.
Regards, Mike
08/06/2008 3:30 PM
Just throwing some more ideas out there for people to look at and think about (I got sick of just seeing threads on water electrolysis). Yes I know these engines are not new, just variations on previous ones.
As I said, I doubt you will be running your cars on them (for obvious reasons such as efficiency).
08/06/2008 4:02 PM
Hate to burst the bubble, but there's nothing new here other than the packaging. Looks like Cyclone realized, like a few million others, that the old steam locomotive can burn anything. Water doesn't care where the energy came from to heat it. There are thousands of patents and thousands of designs for essentially the same thing - at least mechanically. Just package it verbally or physically the right way and everyone thinks it is new. One concern is that any energy transfer or energy transformation has an associated energy loss. If we are concerned over greenness, Cyclones engines will actually produce more carbon dioxide etc as it will require more burned fuel to produce the same amount of horsepower or electricity compared to burning the fuel to directly move pistons or spin a turbine since you loose efficiency with the in-between step of heating the water.
I'm sure there is a niche for them, but this is not the new interesting thing that it is being presented as in this blog - simply more of the same-old.
08/31/2010 9:58 AM
Hate to burst your bubble but you are wrong. The efficiency of the cyclone is way above an ICE and on the lower end of a Diesel. According to their efficiency curve it reaches its efficiency at 1000 RPM's and stays at a constant.
While the steam engine is older than the ICE and the Diesel all of the technology has progressed with new ways to do things and new materials available to allow this to happen.
And what kind of loss do you call it with the flames coming out of the exhaust manifold of an ICE? At least the external combustion gets a complete burn.
Register to Reply 11 comments
4ward2new (1); Anonymous Poster (2); Blink (1); DVader1000 (1); EnviroMan (1); Gabe Spradlin (1); jack of all trades (1); Transcendian (1); vicini (1); YWROADRUNNER (1)
