Previous in Forum: Where to find 6 Inch Schedule 20 PVC   Next in Forum: Compressor question
heat loss from non-insulated pipeline
08/05/2008 8:24 AM
what r probable ways and equations utilized to calculate heat loss from non-insulated pipe.
Data
-hydrocarbon in pipe is at around 300deg C its temp is measured at thermocouple at bottom of vessel where pipe originates.
-avg velocity and temp of air cud be assumed
-pipe dimensions and MOC known
if specific eqations used in industry are provided it will be very helpfull.
The measure of success is not whether you have a tough problem to deal with, but whether it's the same problem you had last year." -- John Foster Dulles
Re: heat loss from non-insulated pipeline
08/05/2008 8:53 AM
Perry - "The Chemical Engineer's Handbook", any edition.
08/06/2008 7:48 AM
i am having two options either heat flow by conduction for which thermocouples error and very low delta t between liquid and pipe surface seems to effect the calculation and if i consider only convective heat tranfer from pipe surface to air determination of coeffcnt poses problem.... n m not able to find perfect eqation....
Register to Reply 2 comments
