Previous in Forum: Winders   Next in Forum: Plastic Ball and Socket
10 comments
Explosion proof wash down motor
08/05/2008 11:14 AM
I'm trying to find a source for an explosion proof wash down motor - 1/2 horse power, 1750 RPM, 56C frame, 460/3/60 - motor will be subjected to low pressure wash down with a mild detergent.
Re: Explosion proof wash down motor
08/05/2008 11:19 AM
If it's explosion-proof [EEx d] then it will be IP55 or greater, which is no problem as far as the detergent is concerned.
In which part of the world is this motor to be used?
Does it matter if the terminal box is increased safety [EEx e] instead?
08/05/2008 1:45 PM
Good afternoon PWSlack,
The motors will be located in the United States. What we are looking for is the ability to have both explosion proof and wash down. We have not been able to find a source that can provide both in the same motor.
Thanks,
tom
Good Answers: 15
08/05/2008 4:18 PM
Have you tried searching GlobalSpec?
Sharkles
08/05/2008 4:24 PM
Yes...and thomas....we are able to find one or the other but not both options. I was hope To find someone whom had a simular need and found a source.
Thanks,
tom
08/05/2008 6:54 PM
Motor Type
3-Phase
Enclosure
IP55
HP
1/2
kW
0.37
Nameplate RPM
1200
NEMA/IEC Frame
80A
Voltage
460
Hz
60/50
Phase
Full Load Amps
1.0
Mounting
Foot
Thermal Protection
None
Insulation Class
F
Bearings
Double Sealed Ball
Frame Material
Die-cast Aluminum
Ambient (C)
40
Rotation
CW/CCW
Nominal Efficiency
73.1
Duty
Inverter
Meets
NEMA MG 1 Part 31: 10:1 Variable Torque and 4:1 Constant Torque
http://www.grainger.com/Grainger/wwg/guideBrowse.shtml
08/05/2008 10:47 PM
Actually there are thousands of these pump. All sanitary sewer pumps in the US are built this way. Also a mining supply pump wilol work. The list above seems to be a good start.
08/06/2008 7:21 AM
Thanks for all the advise with this topic.
tom
08/06/2008 9:36 AM
We get washdown motors of that very same specification at:
NORD GEAR Corporation - $113 each.
US Bearing and Drives also carries them for - $259 each. These are made by Baldor.
Take your pick.
08/07/2008 7:43 AM
thanks for your help,
tom
12/19/2014 2:56 PM
We carry XP hazardous location motors up to 5 HP. You can see the specifications and tables for NEMA and IEC frames at our site under the Hazardous Location (XP) Series motors product. We're glad to help you with any questions.
Register to Reply 10 comments
Anonymous Poster (1); Janissaries (1); jrpeck (1); PWSlack (1); Sharkles (1); StainlessMotors (1); Tom Bates (3); vicini (1)
