Previous in Forum: Soft seat and seat material for ball valve for Brine services   Next in Forum: Chemical reaction
Automotive plastic bumpers
08/06/2008 12:14 PM
Which process is most cost effective in separating the paint from the plastic for recycling, what kind of systems are available out there.
Jerry
Re: Automotive plastic bumpers
08/07/2008 6:19 AM
Hi
try this...
radiator shops use an alkiline solution to remove paint from brass radiators in the past it was caustic soda...try them and see if it works..it does here
Bad things happen WHEN GOOD MEN DO NOTHING..GOOD MEN STAND UP
08/07/2008 1:18 PM
There muct be a bigger market for recycled plastice since the price of oil went up . Clean Plastic anyways.
I read about people using ground up Hickory Nut Shells instead of sand to blast off the paint with high pressure air. It removes the paint without damaging the plastic.
Good Answers: 123
08/07/2008 2:55 PM
How about using plastic chips instead of the shells? Screen the paint chips and all else is recyclable.
Bob
Register to Reply 3 comments
bob c (1); dadw5boys (1); flegelo (1)
You might be interested in: Bumpers, Recycling and Reclamation Services
