Previous in Forum: SMPS   Next in Forum: Earth fault relay operation (in detail )...
Regarding calculation:
08/07/2008 9:06 AM
Dear Sir,
Pl. send the details of Incoming Power Cables ( Al.) for below mentioned Star / Delta and DOL Starters.
1.100 KW De-watering pump Star / Delta Starter
2.50 KW Drainage pump Star / Delta Starter
3.25 KW Cooling Water pump Star / Delta Starter
4.25 KW Compressor Air System Starv / Delta Starter
5.25 KW Oil pump DOL Starter
6.25 KW Oil pump DOL Starter
7.10 KW Oil pump DOL Starter
8.3.7 KW DOL Starter Oil pump
9.3.7 KW Oil pump DOL Starter
10.3.7 KW Vacuum Cleaner Pump DOL Starter
11.1.5 KW Grease Pump DOL Starter
Thanking you sir,
Yours faithfully,
Kishore,
09985376488.
Re: Regarding calculation:
08/07/2008 9:18 AM
This is an engineering news and discussion forum.
The local project cable installer can refer to the project cable schedule for this information. The cable schedule will be found within the contract design documents.
Good Answers: 140
08/07/2008 5:37 PM
Two things...
1) You want some one to do your work for you, and...
2) You really want some one to do your work for you.
08/08/2008 2:30 AM
We need to know the working voltage between phases
Shocking from OZ
nap (1); North of 60 (1); PWSlack (1)
