Previous in Forum: Flow Transmitter   Next in Forum: Orifice bore diameter
Turbine differntial Expansion
08/09/2008 2:16 PM
how turbine diff.expansion is measured with two opposite probes on a collar of turbine shaft
Re: Turbine differntial Expansion
08/11/2008 10:57 PM
When the turbine is in cold condition and de-coupled fix the probes at both ends on the radial faces of the collars and adjust to zero reading on both the probes as indicated on the panel. If axial probes are already available on either side these may be used. After starting the turbine and heating up the readings on either will indicate + or -. If both are minus the readings need to be added up to get the differential expansion. If one is + and other minus, delete the plus from minus to get the diffe. expansion.
Reply to Forum Thread
You might be interested in: Electrical Test Probes, CMM Probes, Fiber Optic Probes
