Previous in Forum: Turbine differntial Expansion   Next in Forum: Flow meter
Orifice bore diameter
08/11/2008 2:07 AM
Hi,
Can anyone here teach me how to calculate the orifice bore diameter??
Thank you for your kind reply...
Good Answers: 230
Re: Orifice bore diameter
08/11/2008 3:00 AM
Hello hotchoco
You need to Specify which orifice, and where it is used.
Is the orifice for solid/liquid/gas?
Is this orifice in an instrument? If so, Make/Model etc advice please.
Is the orifice in a carburettor? If so, advise make/model/altitude to be used at/fuel.
Other useful facts would be helpful, so that a proper answer may be given.
Reply here, with
Kind Regards....
08/13/2008 12:46 AM
Hi,
The orifice will be used in LNG
The fluid state state = liquid
flow rate = 22 m3/hr
pressure = 8.8kg/cm2G
temperature = -162℃
sp.gravity = 0.45
permanent pressure loss = 0.2kg/cm2
08/16/2008 6:51 PM
Are you trying to messure the flow or control the flow?
Still not enough data? Pipe size, liguid viscosity, liquid density Kg/M2
There may be no stupid questions - Some are just poorly contrived !
08/28/2008 12:27 AM
can i calculate the size of orifice bore manually??
I found this formula but I'm not sure whether this i correct??
S= QmGl/ND2FaFm√‾(Gfhm)(FcFp)
Register to Reply 4 comments
hotchoco (2); philroth (1); Sparkstation (1)
You might be interested in: Bore and ID Gages, Bevel and Miter Gears, Steam Traps
