Previous in Forum: DUPVA-1-70 amplifier   Next in Forum: CO2 for Greenhouse gas
refere voltage diode
08/10/2008 6:24 AM
What is the difference between working of LM336 & TL431 programmable voltage reference?
Indonesia - Member - Member from Indonesia Hobbies - Fishing - New Member Engineering Fields - Electrical Engineering - Member
Re: refere voltage diode
08/10/2008 6:30 AM
open www.alldatasheet.com
Fear of God is the beginning of knowledge, God bless you.
08/22/2008 12:06 AM
Thanks for suggestion. But I got the solution.
Actually LM336 is a precision 2.5V shunt regulator whereas Tl431 is programmable shunt voltage reference where output voltage can be set for 2.5 V to 36 V with 2 external resistors.
Tl431 acts as a comparator where there is inbuilt 2.5V ref at one input of comparator & another input is what we connect by means of resistor divider.
These devices find very much benefitial at the ouput of the SMPS where output decreases with increase in load & affects on the regulation.
The application can be seen in any of Fairchild ,Top-Switc SMPS Switch IC.
Register to Reply 2 comments
