Anyone with a crew here?
Two three phase 10000KVA 66kv/11kv stat-delta transformers were in parallel at a substation,their primaries are connected to 66kv transmission line through a single airbreak switch designed to interupt magnitizing current only,which is less than 1amp. The transformers were being removed from service and the secondary loads had been removed.The technician started to open the air break switch with an idear that he will see a small arc as he was interupting the magnetizing current,but he was suprised to here a loud bang and a ball of frame where the air break switch contact had vapourised. What could have gone wrong?
