I need some help with safety rules (personal protective equipment) in a lab. If you have experience or insight I would appreciate your input.
The Lab in question has general policy requirements to wear a lab coat, safety glasses and steel toe shoes at all times. There is an additional requirement to wear nitrile, latex or rubber gloves when handling samples. Handling samples is defined as picking up a sealed jar delivered for analysis, opening and preparing samples and working around apparatus that may have chemicals on the areas touched and the disposal of the chemicals. There is very good acceptance, understanding and compliance
The specific question involves when "chemical goggles" are required when working with strong acids and strong bases.
Because someone was observed pouring a strong acid with glasses and not goggles we reviewed the policy and found some deficiencies.
We implemented a policy that required goggles when handling acids and caustics. The wording may be too restrictive and cause unnecessary use of the goggles.
Two feedback responses were
- Handling includes steps that goggles should not be required. Many samples are brought in sealed jars and not opened. They are visually inspected and stored until consumed then disposed.
- The policy now covers all acids and bases. Highest is 98% sulfuric and strong acetic, hydrochloric, and 40% caustic. Some apparatus use very weak acids, buffers and bases that are not as bad. Our chemist would say no worse than a soft drink or lemon juice.
My questions are:
- Do other labs define when the exposure risk exists and goggles would be required? Example: When a sealed sample container arrives in the receiving window, everyone in the lab must wear goggles. Or Goggles must be worn by the technician from the time the seal is broken until the time the contents are contained or neutralized.
- What is the method or reference to determine the concentration that the strength would be a risk where goggle use is appropriate? Our feedback is that the pH is not a good indicator and may not protect in cases when needed and force goggles in cases where they are not needed.
Any thoughts would be appreciated.
Paddler
