We have a vertical machining center that we put a tooling pallet system onto. The pallet sytem now has the work at a level that the chips fly directly at the Lexan observation ports in the door and are leaving 'marks' in the lexan. The lexan is almost opague now and virtually useless to see thru.
The OEM for the machining center wants $2000 US for replacements! I was thinking that I might be able to have the lexan re-polished and then add layers of sacrificial film of some sort of plastic so that when one layer gets marked up, simply peel it away and presto, we can see thru the window again.
Has anybody else had this problem? What other suggestions might work?
In anticipation of the usual helpful information, a big 'Thanks!'
