Previous in Forum: Lexan Resurfacing?   Next in Forum: my question?
19 comments
How To Miter Cut Aluminum Extrusions?
08/14/2008 5:45 PM
We have aluminum extrusions that need to be precision miter cut at different angles. The extrusions hold honeycomb panels together, they are only .12" thick, and they are about 2''X1.5" with unsupported outside edges.When the honeycomb panels are joined the extrusions butt against each other at different angles and need to have no gaps. Previously, we were using a radial cut-off saw with an 80 tooth blade for this application. Fortunately nobody was hurt! Currently we are using the same saw, but with the fiber cut-off disks commonly used for cutting sheet metal. With some extensive clamping we can make decent cuts, but not to the .002" precision we need. I think we need a real milling machine to do this style of work, but there may be some method to use the cut-off saw to make precision cuts. Some sort of device that clamps the part and then can move a precise distance across the blade, like a mill table. Any suggestions?
Good Answers: 97
Re: How To Miter Cut Aluminum Extrusions?
08/14/2008 7:29 PM
Yes a milling machine using a slotting saw and held by a fixture to support the outside edges.
Good Answers: 230
08/14/2008 7:45 PM
Hello bwire
from me
Clear answer, with the best and cheapest solution to the problem
Kind Regards....
Good Answers: 97
08/15/2008 12:23 PM
Just caught when fog was clearing
08/16/2008 5:15 AM
A milling machine would be an excellent machine for this, as previously suggested.
I'll propose that you google the term 'cold saw', a sawing devise using a milling type cutting blade.
Your answer will include best support of irregular shapes while clamping, & controlled feed-rate while going through irregular thicknesses.
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 123
08/14/2008 10:50 PM
To hold to a .002 tolerance you will need a jig that can locate your material in exactly the same place repeatedly. Next you will need a saw blade that runs that true. I don't know enough about using a milling machine, but I think your specs are beyond the hand operated chop saws and compound miter saws. You might get by with a very fine tooth blade if you can stiffen the blade sufficiently and feed slowly.
Bob
Good Answers: 266
08/15/2008 2:57 PM
Are you looking for precision angle cuts or length cuts. You have stated precision in thousands of an inch. Precision on the angle of the cut would be in degrees.
08/16/2008 12:02 AM
For anyone not already aware, an average reasonable Milling Machine in good condition can work to about 1/10000", eg. highly accurate! And my knowledge is 40 years old, so today, they could be even better!!
08/16/2008 2:26 AM
You need a milling machine set up with a slitting saw on an arbour and a clamping fixture to hold the workpieces. A staggered tooth high speed steel slitting saw about 1/8" or 3/16" thick by 4" dia should work nicely. You can do this work with a small used milling machine, even a hobby type like Grizzly or Smithy will work fine. As far as miter angles go, your fixture for clamping the workpieces could be built on a swivel base like the type found on any common milling vise. Stop playing around with the chop saw and do it the right way :)
08/16/2008 2:48 AM
Did you ever contact your supplier to see if they could supply you with the extrusions already custom cut ?
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
08/16/2008 9:39 AM
It sounds like you lean more towards manufacturing that precision metal working.
If that is the case you should consider anything with a tolerance tighter than +/- .005" to be a purchase part . That is unless there is enough volume to not only "tool-up" but to also have some sort of formal operator training and established procedures for CORRECT machine setup and in process gaging.
It's a real pisser to have a pile of scrap $$ beside a milling machine and an operator looking at you smiling proud as punch of how many pieces he has run not realizing this run of parts will now be made at cost or worse!
With CNC a lot goes good-or-bad in a hurry and .002" with angles is tight.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 97
08/16/2008 7:15 PM
If they've been using a chop saw CNC may be a stretch, ya think
08/16/2008 5:45 PM
I have done and still do use the same tools. I have also used 10 inch plywood blades and we resharpened those before a first use. I would not try using a thin blade for .002 tol. I would rough cut with a thin blade, then surface using a machine tool with a table that can repeat at .002. I have used abrasive and carbide cutting tools for the finish. The biggest problem here will probably be the clamping surfaces on extrusions are not accurate enough for .002. The 1/8 wall is very flimsy to expect .002 repeatability.
08/16/2008 9:41 PM
I would bet there is .002 end play in the saw arbor alone on that chop saw. Add a couple of thou for blade whip and you have a pile of junk.
Others have said it. If it is a long production run and worth doing it yourself hire a competent machinist, let him pick out the best milling and tooling setup he thinks is necessary and let him get to it.
Your best bet, if your material supplier can't supply that stuff within those tolerances, and my bet is he can't he just sells extrusions, is to find a first class machine shop and let them do it. .002 and better is the nature of their business and what they do.
And please, satisfy my curiosity and I suspect that of others, just what are you putting together out of common, cheap, aluminum extrusions that requires those kinds of tolerances? There may be another and possibly better way to do whatever it is you are doing.
j.
08/16/2008 10:57 PM
AMEN to that question. it sounds like these mitered butts are not being "welded" - and also it sounds like they are not even visible.
can you give us a hint?
Out in a Bowt
Good Answers: 97
08/16/2008 11:48 PM
I suspect they are building something and don't want anyone snooping about.
Good Answers: 12
08/17/2008 10:29 AM
I don't know about your .002 tolerance but if you go to Amazon.com, and search for "circular saw blades", you will find dozens of blades in various sizes... some specific to cutting aluminum or cutting non-ferrous metal. I even found 9" Al cutting blades for my miter saw.
Bill
ps I am typically cutting 1/4" round or 1/4" by 1/2" rectangular 6061 in my application.
Good Answers: 123
08/17/2008 12:08 PM
I also use a carbide tipped blade designed for cutting aluminum with great results. I just do not think that the .002 can be held with the tolerances found in the chop and miter saws I have seen.
Bob
08/17/2008 7:08 PM
What you need is a slow speed metal circular saw. They are called various things from 'Drag Saw' to 'Cold Saw' BROBO-Walden are one manufacturer. The machines have a tungsten steel blade with small teeth with the set provided by grinding the corner off alternate teeth on each side. The are very fast and very accurate; less than .001" in my experience. Aluminium blades are generally 1mm thinner than steel cutting blades, though the thickness varies depending on the blade diameter. You can Hire the saws from tool hire companies, so you can try it out before forking out the several thousand for a new machine! they are a whole new world when it comes to cutting metal!
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
08/18/2008 12:37 PM
I agree with the slitting saw suggestions in the other replys.
2 additional suggestions:
1) use a horizontal milling machine
2) mount a rotary table with holding fixture (modified vise to fit your extrusion) to set the angles you need on the bed of the machine.
The early bird gets the worm, but what about the early worm? A.E. Neuman
Reply to Forum Thread 19 comments
Andy Germany (1); Anonymous Poster (2); bob c (2); bob@advanced-grinding.com (1); bwire (4); dadw5boys (1); Jack Jersawitz (1); markar (1); ozzb (1); Sciesis2 (1); sidevalveguru (1); snewkirk (1); snowboy (1); Sparkstation (1)
You might be interested in: Saw Blades, SAW Filters, Precision Shafting
