Previous in Forum: HVAC-AHUs   Next in Forum: Volumetric Flow for Centrifugal Pump
Welder Trade Test
08/18/2008 6:38 AM
Dear All ,
Can you please explain about the " welder trade test" ?
What are the items included for such tests?
Where can i find the details about it?
Thank you
Pathfinder Tags: WTT
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Welder trade test
08/18/2008 7:36 AM
Section IX of the ASME Boiler and Pressure Vessel
Code relates to the qualification of welders, welding
operators, brazers, and brazing operators, and the procedures
that they employ in welding and brazing according
to the ASME Boiler and Pressure Vessel Code and
the ASME B31 Code for Pressure Piping. It is divided
into two parts: Part QW gives requirements for welding
and Part QB contains requirements for brazing. Other
Sections of the Code may specify different requirements
than those specified by this Section. Such requirements
take precedence over those of this Section, and the
manufacturer or contractor shall comply with them.
Look over to the next challenge
08/19/2008 3:37 AM
where can I find the ASME codes?
Register to Reply 2 comments
