Respected All,
We are facing one of the walk in chiller,in the unit semi sealed comperessor was there it burnt out & we replaced with reciprocating compressor with less capacity,neither replaced the expension valve nor adjusted.now suction line & compressor is frezzing even temp. is also not coming down less than 12c some time comes down to 9c if compressor runs full night then it comes to 5c but once the door opens goes to 12c.i taken advice one of my colleague he said adjust the expension valve means (tight it little bit ) but nothing happend,then he suggested inside the expension valve after the filter one bullet type(spare part) is there from where the refrigerant goes to cooling coil that will be of little big capacity i checked its no. is 03, he hold it needs to change with no.04 then hopefully it will be ok.Could u explain in details but may be the reason to come out of problem & what is the reason of frezzing suction line.thanks & regards manish
