Previous in Forum: Suction Line Freezes Compressor   Next in Forum: What is Water Hammering?
Calculating Gross Efficiency for a Water Pump
08/19/2008 8:19 AM
Please help me calculate the gross efficiency of pump when forcing cold water through the system.
Total static lift 14.15m
static suction lift 2.05m
Discharge 0.1m3/s
Power input 22kw
Total length of suction pipe 8.5m
Total length of discharge pipe 47.5m
Diameter of suction pipe 250mm
Diameter of discharge pipe 200mm
Assume f=0.006 K foot valve 2 K bend 0.25
Re: Calculating Gross Efficiency for a Water Pump
08/19/2008 10:45 PM
How about the easy way? Have a look at the pump performance curve.
And if you don't have it - go your supplier/manufacturer.
08/20/2008 12:28 AM
Jan Mashele,
As highlighted by "Guest", you may obtain the pump efficiency from pump curve dedicated to your pump...
When we talk about pump, the first thing is the type. Centrifugal ? Reciprocating ? The efficiency could be very different.
Pump efficiency for Reciprocating pump could be as high as 80-85%
Pump efficiency for centrifugal pump may vary from 40-80% (even lower but not cost effective).
During design phase, for centrifugal pump, the following methods may be consider :
08/20/2008 5:05 AM
Total lift = 16.2m
Assume density = 1000kg/m3 and gravity = 9.81ms-2
Pressure change = 16.2m x 1000kg/m3 x 9.81ms-2= 1.59e5 N/m2
System work = 1.59e5N/m2 x 0.1m3/s = 1.59e4 Watts
Input power = 2.2e4 Watts
Therefore system efficiency = 1.59e4/2.2e4 = 72% or so.
Ready for the next time?
Register to Reply 3 comments
Anonymous Poster (1); JoeWong (1); PWSlack (1)
