Previous in Forum: Compressive Strength of Fe410   Next in Forum: A/C Freezing on Compressor and Suction Line
Water Hammer Wave Speed
08/20/2008 4:11 AM
Why water hammer wave speed is equal to the speed of sound?
Good Answers: 230
Re: water hammer wave speed
08/20/2008 4:34 AM
Hello nidalabdalla
Refer: http://www.plastomatic.com/water-hammer.html
Tech Brief:
The Effects of Water Hammer And Pulsations
Quick closing valves, positive displacement pumps, and vertical pipe runs can create damaging pressure spikes, leading to blown diaphragms, seals and gaskets also destroyed meters and gauges.
Liquid for all practical purposes is not compressible, any energy that is applied to it is instantly transmitted. This energy becomes dynamic in nature when a force such as quick closing valve or a pump applies velocity to the fluid.
Surge (Water Hammer)
Surge or water hammer, as it is commonly known is the result of a sudden change in liquid velocity. Water hammer usually occurs when a transfer system is quickly started, stopped or is forced to make a rapid change in direction. Any of these events can lead to catastrophic system component failure. Without question, the primary cause of water hammer in process applications is the quick closing valve, whether manual or automatic. A valve closing in 1.5 sec. or less depending upon valve size and system conditions, causes an abrupt stoppage of flow. The pressure spike(acoustic wave)created at rapid valve closure can be high as five(5) times the system working pressure.
Unrestricted, this pressure spike or wave will rapidly accelerate to the speed of sound in liquid, which can exceed 4000 ft/sec. It is possible to estimate the pressure increase by the following formula.
Importance of Using this Formula While there are many online water hammer calculators, we have found wide variety in the results. We therefore recommend using old fashioned pencil and paper and this formula:
Water Hammer Formula: P = (0.070) (V) (L) / t + P1
Where P = Increase in pressure
P1 = Inlet Pressure
V = Flow velocity in ft/sec
t = Time in sec.(Valve closing time)
L = Upstream Pipe Length in feet
Here's an example of pressure hammer when closing an EASMT solenoid valve, with a 50 ft long upstream pipe connection:
L = 50 ft
V = 5.0 ft / sec( recommended velocity for PVC piping design)
t = 40 ms(solenoid valve closing time is approx. 40-50 ms)
P1 = 50 psi inlet pressure
therefore, P = 0.07 x 5 x 50 / 0.040 + P1
or P = 437.5 psi + P1
Total Pressure = 437.5 + 50 = 487.5 psi
Pulsation
Pulsation generally occurs when a liquid's motive force is generated by reciprocating or peristaltic positive displacement pumps. It is most commonly caused by the acceleration and deceleration of the pumped fluid. This uncontrolled energy appears as pressure spikes. Vibration is the visible example of pulsation and is the culprit that usually leads the way to component failure.
Unlike centrifugal pumps(which produce normally non-damaging high-frequency but low-amplitude pulses), the amplitude is the problem because it's the pressure spike. The peak, instantaneous pressure required to accelerate the liquid in the pipe line can be greater than ten (10) times the steady state flow pressure produced by a centrifugal pump. Damage to seals gauges, diaphragms , valves and joints in piping result from the pressure spikes created by the pulsating flow.
Remedy
Suggest that you install a pulsation dampener. Dampeners provide the most cost efficient and effective choice to prevent the damaging effects of pulsation. A surge suppressor is in design essentially the same as pulsation dampener. The difference primarily lies in sizing and pressurizing.
The most current pulsation dampener design is the hydro-pneumatic dampener, consisting of a pressure vessel containing a compressed gas, generally air or Nitrogen separated from the process liquid by a bladder or diaphragm. The dampener is installed as close as possible to the pump or quick closing valve and is charged to 85% of the liquid line pressure. Proper sizing of the pulsation or surge suppressor requires several calculations. A close contact with the suppressor's manufacturer will ensure the correct sizing for a particular application.
Conclusion
By knowing how to avoid situations that will create water hammer or pulsations during the specification process, or while trouble shooting, you can eliminate a lot of problems, failed valves and equipment, and costly downtime.
Trust that answers your Question.
Kind Regards....
10/05/2012 4:16 AM
Dear sparkstation,
Will this phenomenon applies to compressed gas pipe too?
Suppose a air at 15 barg pressure is supplied to a consumer 500 m away, if consumer suddenly closes the shut off valve at their end, what will be the pressure rise before shut off valve and how long it will take to travel to supply point?
Good Answers: 143
08/20/2008 11:41 AM
So, you're asking why a sound propagates at the speed of sound? Is there more to your question?
Register to Reply 3 comments
Anonymous Poster (1); Sparkstation (1); TVP45 (1)
