Previous in Forum: Material Codes by Country   Next in Forum: Evaporator Cooling Coils
8 comments
Testing Underground Water Lines for Leaks
08/21/2008 5:19 AM
is there any system to test underground leakages of water line
thoughts becomes things.
Re: leak testing
08/21/2008 5:47 AM
  • What pressure and temperature?
  • Potable or non-potable?
  • What diameter and length?
  • What materials of construction?
  • Urban or rural?
  • How deep is it buried?
  • What sort of terrain?
  • What sort of access?
Please help the forum to offer appropriate advice.
Re: Testing Underground Water Lines for Leaks
08/21/2008 10:50 PM
See www.fluidconservation.com
08/21/2008 11:16 PM
Yes, with the right equipment you can use accostic emission spectroscopy to determine location of pipe crack (hole) within a few feet. I have seen it work on lines several miles long.
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
08/22/2008 7:47 AM
There are several companies that sell the hardware. Look at the magazine waterefficiency.net. Also, look at the following websites: subsurfaceleak.com, sweerin.net.
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
08/22/2008 10:17 AM
I meant sewerin.net.
08/22/2008 10:14 AM
There are several methods, including acoustic and video. But as others have mentioned, more information will get you better answers...
08/22/2008 10:35 AM
Try this site www.echologics.com
Good Answers: 25
08/23/2008 9:32 AM
As I have supervised the under ground installation of numerous public potable water systems I believe that your question is best answered with out asking more questions. You will need to be able to close a valve at each end of the section of water main you wish to test. You must also have a tee in the line so that you can completely fill the line with water, and install a pressure gage and an inlet valve that can be used to apply air pressure or nitrogen to the system. After pressurizing the system, monitor the air pressure gage. If the system is in an area where it will warm up the pressure gage will indicate a little more pressure, a cooling effect will give an opposite reading. If the pressure holds, you have no leaks, of course if the pressure reading falls you have a problem. The purpose for testing in this manner is so that if the pipe breaks, you will only have a minor issue instead of an explosion to deal with.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
Register to Reply 8 comments
Anonymous Poster (3); EnviroMan (1); Old Coal Man (2); PWSlack (1); Toomuchfun (1)
