Previous in Forum: Air Flow and Static Pressure Measurement with Pitot Tube   Next in Forum: Why Do Polymers Shrink?
26 comments
High-Temperature Materials
08/21/2008 8:41 AM
Is there a transparent ceramic or glass or plastic that can withstand temperatures of 3000 to 4000 degrees Fahrenheit without softening, melting, or otherwise becoming distorted? If so, what are the details: name, specifications, U.S.manufacturers?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: High temperature ceramics
08/21/2008 9:02 AM
That's very hot, but you could look into quartz glass.
http://en.wikipedia.org/wiki/Fused_quartz
There's some external links there, listing manufacturers. Best bet is to contact one of them.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: High-Temperature Materials
08/21/2008 9:17 AM
Hydrogels?
08/22/2008 4:29 AM
probably the best available
www.quartz.saint-gobain.com/ - 25k
Insanity is not running into a brick wall over and over again. Insanity is expecting a different result each time.
08/22/2008 8:23 AM
Thank you for your reply. I shall investigate.
Origo
08/22/2008 4:47 AM
so hight temperature withstand, and has tranparent feature?
1600-2200centidegree.
marking.
08/22/2008 8:25 AM
Thank you for your reply. I appreciate your help.
Origo
Good Answers: 94
08/22/2008 6:14 AM
The data I have shows fused silica or quartz is limited to 950°C - 1750°F.
08/22/2008 8:28 AM
Thank you for your reply. I appreciate that you took the time to respond.
Origo
08/22/2008 6:27 AM
http://www.xsglass.cn/
made in china. they can produce such glass from 500----1730 C /100mm thickness
other can rich to 2000c
08/22/2008 8:35 AM
Thank you for your reply to my question. I shall explore the information that you provided.
Origo
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
08/22/2008 8:27 AM
I would look at sapphire. What is the application?
Good Answers: 94
08/22/2008 8:37 AM
3000°F is close to the melting point of sapphire but I can't think of a transparent material that goes higher.
08/22/2008 9:02 AM
Thank you for your additional reply. Initially,I should have listed additional parameters, such as being colorless, thickness not to exceed 0.5 inches, possess the ability to be cast as a machine part of approximately 16 square inches, and to be able to transmit wavelengths of 1000 to 2000 Angstroms without distortion.
Origo
Good Answers: 73
08/22/2008 9:17 AM
That's a very tall order at those temperatures!
08/22/2008 10:29 AM
Yah - starting to sound like he needs a very high-purity grade of Unobtanium!
Good Answers: 94
08/22/2008 10:51 AM
I can get some of that if the price is right.
Good Answers: 73
08/22/2008 10:54 AM
Where's Stinky Pete when you need him?
Good Answers: 94
08/22/2008 9:35 AM
1000Å is into the far U.V., even quartz & sapphire are going to struggle with that.The materials that can transmit those wavelengths like magnesium fluoride or lithium fluoride won't take the temperature and are horrible materials to handle.
08/22/2008 2:52 PM
Again, thank you for your input. You have been very helpful. Judging from the replies that I have received, I am convinced that I shall have to try an alternative approach to the problem in order to reach my goal.
Origo
08/22/2008 11:33 AM
yOU CAN THINK OF CHEMICAL VAPOUR DEPOSITION COATINGS(CVD) FOR YOUR REQUIREMENTS. CVD COATINS CAN BE DONE FOR THE FOLLOWING PARAMETERS
  • HIGH TEMPERATURE
  • OPTICAL QUALITY
  • REFLECTIVITY
  • ELECTRIC CONDUCTION AND MAGNETIC/NON MAGNETIC
  • CORROSION/CAVITATION
  • ABRATION/EROSION ETC.......
MOST REQUIRED PARAMETERS CAN BE ACHIEVED IN CVD COATINGS
YOU CAN ALSO GO FOR NANO COATINGS
I WILL PROVIDE THE CONTACT DETAILS FOR CVD COATINGS SHORTLY
REGARDS
MAHI SRIRAM
Hobbies - DIY Welding - pipewelder
08/22/2008 8:45 AM
I think fused silica would be the best bet.
pipewelder
pipewelder
08/24/2008 8:29 PM
Hello,
I'm no engineer but this may help. There is a product called aerogel. Aerogel may have the properties you desire. Google the name or try this link: http://www.unitednuclear.com/aerogel.htm
It may be the same as others here have suggested but they called it by its proper name. I have some small samples of aerogel and it is amazing! It is so light it doesn't register with the senses as other items would. It has super insulating properties also.
Everyone brings joy, some by arriving, some by leaving.
Good Answers: 15
08/25/2008 6:55 AM
Aerogel may not be a viable item. It is an insulation and I have used it for that but it is either a compacted powder or a fiber so I don't see how it could be used for and type of pressure boundary.
08/28/2008 2:03 AM
  • HIGH TEMPERATURE
  • OPTICAL QUALITY
  • REFLECTIVITY
REGARDS
MAHI SRIRAM
Good Answers: 94
08/28/2008 4:04 AM
You still need a substrate to support the coating & the substrate has to meet the same parameters.
10/24/2008 11:44 PM
Welding is also one good option
Register to Reply 26 comments
Anonymous Poster (3); Billdad (1); Bricktop (3); cnpower (2); EnviroMan (1); Morgan 23 (2); Nigh (5); Origo (6); pipewelder (1); PWSlack (1); Ryan (1)
