Previous in Forum: 304/316 portable tester   Next in Forum: Water Cooled Genset
Temperature vs. Yield Strength
08/21/2008 11:38 PM
Pls can someone provide me the temperature Vs yield strength for 25CD4 & 42CD4 material. -- V. Poovelan
Re: Temp Vs Yield Strength
08/22/2008 2:02 AM
The best I could come up with for you is using the cross-reference that 42CD4 is equivalent to AISI/SAE 4140 and then going with ASME Section 2 Part D for SA-574 bolting product.
According to this, the yield strength would be as follows:
Deg. F : Yield (ksi)
-20 to 100 : 135.0
200 : 126.9
300 : 121.7
400 : 117.6
500 : 114.0
600 : 110.4
650 : 108.4
700 : 106.2
750 : 103.7
800 : 100.9
850 : 97.7
900 : 94.1
950 : 90.0
1000 : 85.5
I hope that is of some use to you.
Out of curiosity - are you using this material for bolting, or shafting, or ....?
Good Answers: 243
08/23/2008 8:20 PM
Presuming 90% martensite?
What temper temperature? I dont have a copy of SA 574...
milo
08/23/2008 11:33 PM
I posted a copy of A574 here
Good Answers: 243
08/24/2008 10:23 AM
Great utility Guest. Learned two things with that ne.
milo
08/23/2008 11:37 PM
As per section 5.5:
The screws shall be heat treated by oil quenching from above the transformation temperature and then tempering at a temperature not lower than 650°F.
