Stilljester,
Your informative restoration blog inspired me to pull my old CA160 from the back of the garage and try to get it back in shape. I don't have the technical skills you do but I've slowly begun taking the big pieces off for repainting. I don't have much rust. I have the fuel tank off but the petcock assembly has corroded. The bottom half disintegrated when I put a wrench on the nut. I pulled the bottom half away and found three corroded screws leading up into the petcock toward the tank itself. They wouldn't budge and I drilled them out but still no way to move the remaining part. How is the petcock attached to the tank and what is the best way to get it loose?
Secondly, what was the best source for parts for your project?
I've got several more questions but don't want to swamp you.
thanks,
wilhelm45
