Previous in Forum: Tank / Pressure Materials Weight Calculation Formula   Next in Forum: pump motor frequency
depressurize
08/24/2008 8:08 AM
Pls help me ,I need depressurize gas (uncontinuse) from 100 bar to which pressure for flaring,
Do you propose pressure control valve or globe valve Or restricetion orifice,...?
Regards,
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: depressurize
08/25/2008 3:49 AM
Usually for this service it is a good practice to install a pressure control valve betwen your system and flare header.
Hope this help
Look over to the next challenge
Re: depressurize
08/25/2008 8:29 AM
dear,
subject:-depressurize
you want to reduce the pressure from 100 bar to 10 bar or 5 bar
you can use the pressure regulator valve, you can adjust as per your requirement
thanks
r.c.mandal
Re: depressurize
08/25/2008 5:47 PM
First of all, you have to define the purpose of the depressuring.
Emergency Depressuring intended to evacuate system inventory (flammable, toxic, explosive, hazardous, etc) to disposal system as fast as possible during process and non process contingency in order to minimize possible catastrophic events.
Manual depressuring is intended to evacuate system inventory in proper manner so that the system can be properly purged and inert-ed for system maintenance or other purpose.
The depressuring strategy is subject to the purpose of depressuring and limitation of system. Thus, control or non-control depressuring may be adopted. Read more in Controlled and Non-controlled Type Depressuring.
Anonymous Poster (1); JoeWong (1); user-deleted-1104 (1)
