Previous in Forum: Globe valves   Next in Forum: ABOUT CG GRINDING
Spreader beam
08/24/2008 11:34 PM
Dear sir, I am rajkumar,Design engineer from bangalore, India, For one of my project , i was advised to go with spreader beam or Evener Beam method to lift approximately 10 ton cylindrical shell .Kindly help me to know about this spreader beam method and how to design.
with Regards,
rajkumar.M
Re: Spreader beam
08/25/2008 12:17 AM
Here are some suggestions:
  1. Borrow or rent a spreader beam from local crane company
  2. Buy an off-the-shelf beam that has been engineered and tested such as:
http://www.buylifters.com/PDF/STRONGBAC/SpreaderBeams.pdf
Good Answers: 74
Re: Spreader beam
08/25/2008 12:57 AM
The reference given by Guest is good. If you want to design it yourself, you will easily be able to see that the beam is primarily a compression strut and carries no bending.
Another option is a beam such as the one shown here. This beam is a double cantilever and carries bending moment but no axial force. The choice is yours.
Bruce
Re: Spreader beam
08/25/2008 12:40 AM
But, if you have to design yourself ...........
The best resource is:
The AISC Engineering Journal, Fourth Quarter 1991 - 10 page article by David Ricker titled "Design and Construction of Lifting Beams"
Available for $10 (US) at:
http://www.aisc.org/Template.cfm?Section=Technical_Answers&Template=/Ecommerce/ProductDisplay.cfm&ProductID=861
Re: Spreader beam
08/26/2008 6:13 AM
Once designed, it needs to be built, witness-tested and certified by the surveyor-inspector of the organisation's lifting equipment insurance company at prescribed intervals, and maintained on the local lifting equipment register. Only then will it be covered by the insurance comapny's policies in the event of an incident or accident.
As far as lifting equipment goes, insurance is everything.
Register to Reply 4 comments
Anonymous Poster (2); ba/ael (1); PWSlack (1)
