Previous in Forum: Major Challenges for Drives   Next in Forum: Can You Solve This (DC Loading)1
Earthing, high meter readings and high power consumption?
08/25/2008 9:36 AM
Does poor earthing system in domestic house causes high readings in meters,resulting in high power consumption.?
New Zealand - Member - Kiwi
Good Answers: 29
Re: Earthing, high meter readings and high power consumption?
08/25/2008 4:45 PM
Generally not, no.
paulusgnome
Engineering Fields - Power Engineering - Projects Engineer
08/26/2008 2:48 AM
NO!
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
08/26/2008 3:46 AM
No. Ordinarily there should be no current on the earth conductor. Its purpose is to achieve a high level of safety in the event of a fault.
What could be done to improve the earthing on this particular installation?
08/27/2008 1:04 AM
Yes, this is due to leakage of current continueously,
10/13/2023 6:51 AM
...then that's a safety issue as a priority for correction, ideally before someone gets hurt/killed and a measure of unpopularity develops with the fire insurance provider.
Good Answers: 15
08/30/2008 5:14 AM
What do you mean? Please be more specific.
If you are having earthing problems and suspiciously high meter readings then you would be well advised to get an electrician in to check your system as it could be VERY dangerous!
aamersyed (1); capblanc (1); Paulusgnome (1); PWSlack (2); SAK (1)
