Previous in Forum: Start-Up Problem Komatsu FD35T-7 Forklift   Next in Forum: Good Alternator But Low Output to Battery
14 comments
Onan Genset
08/25/2008 1:09 PM
How do you addvance the timing on a 70's Onan 6.5 kw Genset?
Good Answers: 123
Re: Onan Genset
08/25/2008 10:57 PM
Please send model #. I have a few Onan generator service manuals and may be able to help.
Bob
Re: Onan Genset
08/26/2008 2:37 PM
Thank you, I will get the numbers for you tomrrow.
Re: Onan Genset
08/28/2008 10:05 AM
Adjust to specs? or advance it more? why?
Keith E Bowers, PMP
Good Answers: 123
Re: Onan Genset
08/28/2008 12:35 PM
Timing adjustments on older equipment are commonly required in order to return timing to correct specs. As multiple components wear, the accumulated slack shows up as retarded timing (relative to original specs). Crank to crank sprocket keyway, crank gear to cam gear, cam to distributor gear, contact set rubbing block, all could affect timing. And all wear would retard timing.
Bob
Re: Onan Genset
08/28/2008 1:55 PM
Good Morrning,
I now have the model nombers, and they are as follows:6.5 NH-3CP7120140, AND SERL. NO. 0475948140. The reason I want to addvance the timing is, I am trying to run it on HHO gas. in other words: water.
Thank You for youe help.
333Loner
Good Answers: 123
Re: Onan Genset
08/28/2008 11:45 PM
I am home now. I will do some searching tomorrow at work. Patience.
Bob
Re: Onan Genset
08/29/2008 3:29 PM
Thank you :-)
Good Answers: 123
Re: Onan Genset
08/30/2008 1:22 AM
Five different design Onan generator service manuals. But not a NH series among them. I contacted the local Onan distributer today and asked for a copy of the service manual. I hope to hear back from them on Tues.
Bob
Re: Onan Genset
08/30/2008 1:42 PM
I have no idea what NH stands for; what I can do is thank you for all the trouble you have gone through for me :-)
Good Answers: 123
Re: Onan Genset
08/30/2008 4:13 PM
Lets just save those thanks until I actually give you something worth having.
6.5 NH-3CP7120140
6.5 This is the rated output in KW
NH This is the general family of styles of generator
3C This is a further refinement of the way that a series NH was built. An example of this would be an RV designed generator, or a standby generator, both of which started with the same basic engine design.
P7120140 is the exact combination of parts used on the generator.
It might help to trace if you can tell me somethings about the genset. How old? What was it originally used for?
Bob
Re: Onan Genset
08/30/2008 5:11 PM
This Genset was in a RV before I got it. I think it was a 70s model.
Re: Onan Genset
09/03/2008 5:03 PM
This Genset may be a 60s model also???
Good Answers: 123
Re: Onan Genset
09/03/2008 9:25 PM
http://www.perr.com/onan.html
The above site will give you a good deal of information on your generator.
From the info you gave me I have decided you have the early NH series. That is not bad, I have an older AJ series that runs at 3600 rpm. Your motor is still in production. And parts are plentiful. If you need more info let me know.
Bob
Re: Onan Genset
09/04/2008 1:35 PM
Thanks for the web site, it was good info. I found out what I needed. And once again thanks!!!
Register to Reply 14 comments
333Loner (5); Anonymous Poster (2); bob c (6); Keith E Bowers (1)
You might be interested in: Timing Screws, English Pitch Timing Belts
