Previous in Forum: Jules Verne   Next in Forum: IR Receiver
Philippines - Member - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Instrumentation Engineering - New Member
hook-ups
08/26/2008 1:13 AM
hi guys,
Could you lend give me some installation hook-ups for temperature transmitters?
Every project that I've worked into didnt have some, most hook-ups that are available are for pressure instruments only.
Even Internet links will do.
sep_gp20@yahoo.com
"Autobots.......TRANSFORM!!!!" -- Optimusprime
Pathfinder Tags: hook-ups
Re: hook-ups
08/26/2008 6:28 AM
The hook-up drawing is often done by the Mechanical Designer, and shows the installation team how to connect the instrument to the process vessels and pipework. It usually lists the installation materials to be used in the form of a take-off table. The Mechanical Designer needs access to the Original Equipment Manufacturer's [OEM] user manual, so as to interpret the OEM installation instructions for the site team.
Once the instrument has been installed correctly, the value of the hook-up drawing is questionable.
[It is inadvisable to publish a full e-mail address in a global discussion forum. Spam robots surf these sites and harvest e-mail addresses with a view to bombarding them with multiple unwanted advertisements for pharmaceuticals, scam appeals for getting money out of undeveloped countries, and directions for accessing lewd material that some might consider pornographic.]
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: hook-ups
08/26/2008 7:53 AM
There's a lot of information here:
http://www.emersonprocess.com/rosemount/products/temperature/index.html
I use some of these Rosemount temperature transmitters, pretty much the same type hook-up as a pressure transmitter.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: hook-ups
09/09/2008 12:07 PM
We use Minco TT176 transmitters with S603 probes to moniter the bearing temperatures on some of our production machines and they seem to work well. I think there web site is www.minco.com
Register to Reply 3 comments
Bricktop (1); PWSlack (1); RickZ (1)
