Previous in Forum: Motor Shaft Failure   Next in Forum: How Do I put in to running my CHILLER - 20TR ?
Heat Exchanger Plugging
08/26/2008 2:12 AM
Hi, can i ask how many percentage of tubes can be plugged or what is that limit numbers of tubes that can be plug in a U heat exchanger... And also what code or reference standard can i find this.. thx
Re: Heat Exchanger Plugging
08/26/2008 3:23 AM
If there are N tubes, the maximum number that can be plugged is N-1.
The performance of the exchanger will be affected starting with the 1st tube plug.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
09/02/2008 9:44 AM
Yes, you are in right. Theoretically the maximum number that can be plugged is N-1. But for sure practically is impossible to operate an exchanger plugged N-1 tubes.
Look over to the next challenge
Good Answers: 21
08/26/2008 4:04 AM
Hello
From our practice and internal regulations are allowed to be plugged 15% from total tubes. For additional details see API 660. Hope tis help.
08/26/2008 12:07 PM
You don't say what is causing the plug. If the tube is plugged because the water freezes, the answer is one tube. A frozen tube will burst and your start to leak your refrigerant with your water...
Labyguy (1); PWSlack (1); user-deleted-1104 (2)
You might be interested in: Cores and Tubes, Microwave Tubes, Vacuum Tubes
