Previous in Forum: A Temporary Sabbatical - Off To Iraq   Next in Forum: Linux Problem Connecting to Internet
oil hot water heater
08/26/2008 11:51 AM
I have a hot water heater that is oil fed, i ran out of oil in the tank and now i have no hot water. I was told that the line has to be purged. How do I do that?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: oil hot water heater
08/26/2008 1:27 PM
Yes, you must purge the air out the line. On the burner pump, you will find a bleeder fitting. Loosen this a couple turns, then start the burner,( make sure you have a container to catch the oil). You will see oil, and air sputter. Run until the oil runs clear, and close the fitting. It may time out before this happens, so you may have to do it more than once.
What brand of burner do you have? With a Beckett, if you tried to light this a few times, without the burner lighting, it may "latch", preventing future tries. To "unlatch" hold the button down until both lights alternately flash, then stop. It should start then.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Reply to Forum Thread
