Previous in Forum: Cracked head   Next in Forum: Gearbox for supercharger
Is any problem if whole chiller plant elevation changes?
08/27/2008 1:10 AM
hai guys,
For one automotive industry, we have 2 chiller units one is 160 TR another one is 240 TR. Initially this 240(flow rate 192 m^3/hour) chiller unit is at the elevation of 18 meter, due to some customer request we changed this to 0.0meter, without any changes. But, i know this 1TR is directly proportional to difference in temperature and also the flow rate,
For this, i think so we didnt get this flow rate 192cub. meter per hour at this ground level, also this is the closed looped process cooling line.
What i can do to maintain this 192 m^3/hour..
Awaiting for your precious reply
Regards
skarthee
Be Mechanical
Pathfinder Tags: chiller elvation changes
Good Answers: 19
Re: Is any problem if whole chiller plant elevation changes?
08/27/2008 10:56 PM
If the elevations of the water piping was unchanged, you may have increase pressure head which will reduce the pump flow rate. If this is the case, some options are 1. install a higher capacity pump, 2. increase piping size to reduce system pressure losses, or 3. install a parallel water system loop to reduce pressure drop to increase flow rate.
What were pump suction and discharge pressure before change, and what are pump pressures after change?
I would guess larger pump might be least expensive, but you will need to determine.
08/28/2008 12:10 AM
The standard rule for flow rate is 2-2.5 gallons per minute per ton of refrigeraton effect. 160 Ton would of course be 320-400 gallons per minute. The elevation measured in height along with drag & flow coefficients of the pipe result in the "head' output of the pump.
That is .00757 to .00946 cubic meters per minute per ton. For the 160 ton unit it would be 1.21 to 1.51 cubic meters per minute.
From what you are writing it sounds like you should be able to run a 400 ton chiller.
http://www.hydro-zoneinc.com/ftp@hydro-zoneinc.com/Water%20Treatment%20Information/Engineering%20Formulas.doc
http://www1.eere.energy.gov/industry/bestpractices/software.html#psat
Look down the list here for the PSAT-Pumping System Assessment Tool. It is a great tool for checking your pump sizing, valves, fittings, pump impeller trim & motor sizing.
08/28/2008 7:51 AM
What are the chiller's Make & Model (ex. if Trane CVHE, RTHB)? Are they equipped with Building/Equipment Automation (ex. UCM, UCP2..)
Ur absolutely right about proportionality of its operation..
What are the inital steps you have taken? (i.e)
Tiil then
08/28/2008 9:34 AM
Rather then changing your pumps or redesigning your system, go back to your original mfg'r pump flow charts. The chart will show various models @ various heads and GPM and more often then not the Pump Manufacturer can cut you a new impeller to accomodate the additional head. Then your done and you can move on to the next project.
Good Answers: 19
08/28/2008 10:51 AM
IF there is sufficient room in the pump casing for a new impeller, and IF the motor has sufficient rating to handle a larger power requirement, this is an excellent idea. If either the pump casing or pump motor are too small, this will not work.
Anonymous Poster (1); Maxozone (1); mechanical (1); Ried (2)
You might be interested in: Gas Flow Meters, Flow Meters, Turbine Flow Meters
