A close friend of mine recently purchased a used Peterbilt tractor, the price for a
loan was 1/2 the amount he was paying to lease from his trucking company.
So....Now he is an owner/operator.
The tractor he bought had recently had the engine rebuilt, the first week he drove
it the low coolant light illuminated on the second day, and on a run from NY to FLA
and then back to NJ the truck used a total of 7 gallons of coolant.
There wasn't any coolant visible in the oil, and he seemed to notice that at
times under duress he'd see white smoke from the stacks, but not much.
At that time I told him it sounded like a cracked head, he took it back to the
dealer where he purchased it and they sent him to a repair facility that
honored the warranty for the rebuild that was done.
This started July 3, since then he's been to 3 different repair facilities,
he's had cams replaced, the turbo replaced twice within 2 weeks, etc.
All this work was done to honor the warranty and all he has been out financially
is the time spent being repaired instead of producing income.
Today, August 26th, they applied pressure to the cooling system and detected
that the head is indeed cracked when coolant started seeping into the valve cover.
OK.... my question is.... can a torque wrench be used to determine if the head bolts
were properly torqued ? I have a click type torque wrench and it does work in
forward as well as reverse, but would it be accurate?
We were wondering if the head was improperly torqued resulting in the crack,
or perhaps the cylinder sleeve was improperly fitted to the block.
It is a Cummings ISX 375HP DOHC
Thanks in advance....
