Previous in Forum: about final year project   Next in Forum: OVER HEATING OF IBH - 10 DRILLING MACHINE
Consumed Power / Load Study
08/27/2008 2:10 AM
The Power supply INPUT drawn by an electrical motor under load conditions is determined by the power KW required to drive the connected mechanical load under normal operating load conditions.
The Mechanical Load Factor = Mechanical Load KW / Motor Shaft rated output KW
Consumed Power KW = [ Power Input KW / Motor Efficiency ] X Load Factor
Is this correct ?
Thank you
Good Answers: 230
Re: Consumed Power / Load Study
08/27/2008 2:41 AM
Hello Jeff Millar
Basically: Yes.
There are other small losses (bearing noise, heat, rotor windage, fan losses etc) but these all come under the basic heading of Efficiency.
Do not forget the Electrical Power Factor of the motor, at variable loads and speeds. If the motor is large, an automatic Power Factor Correction unit may be used to minimise losses.
Kind Regards....
08/28/2008 9:27 AM
Introducing an alternative:
pump motor is calculated using the following formula:
P=γ Q h/ ŋ 3600
Where:
- P will be computed in W;
- γ is specific weight in N/m³;
- Q is pump flow capacity in m³/h;
- H is discharge height in m;
- ŋ is the motor-pump system total efficiency factor ( 0.50÷0.70 )
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
08/28/2008 9:34 AM
Introducing an alternative in particular ( sorry before I posted the reply as a guest):
P=γ Q h/ ŋ 3600
Where:
Look over to the next challenge
Good Answers: 137
08/28/2008 11:57 AM
Your first sentence is correct but the 2nd formula is wrong.
Consumed electrical power kW = power input kW = power output kW / motor efficiency = mechanical load kW / motor efficiency.
One thing you need to watch is that motor efficiency varies somewhat with load (actual power output). Motor data sheets usually give efficiency at 100%, 75% and 50% of rated power output.
Cheers........Codey
Register to Reply 4 comments
Anonymous Poster (1); Codemaster (1); Sparkstation (1); user-deleted-1104 (1)
