Previous in Forum: PID Controller   Next in Forum: Hot Lap-Top
ip address changing
08/27/2008 11:52 PM
hi, why does my ip address changes every time i connect to the network/internet,. is the a way to fix permanent my ip address?
Re: ip address changing
08/28/2008 6:24 AM
Not simple! you can find your IP changes every time you surf on net
Thats because public net, cut to short. the sever arrange a temp IP for you every tiem automatically.
once you use a relay line. you can get a fix IP number. but it will be very expensive. and will waste net resource if you own this domain by yourself.
08/28/2008 8:39 AM
There are several FREE fixed Domain addresses you can sign up fo...
If I remember correctly there is nodns.com
Try googling for free fixed IP and you will find at least these two...
Then you have to asign your ISP to direct your internet to this service so that it always appears to have the same IP address.
All for free!!! Its mainly used when you want to set up a web cam and you can't keep changing the IP address etc...
Good luck!
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
08/28/2008 9:51 AM
Your IP address is assigned dynamically every time by your Internet Service Provider when you're getting connected to its server. Most of ISP time to time are changing communicating routes [chain of proxy servers, communicating channels etc] due to its needs to minimize prepaid traffic cost. This factor as well might influence on your overall IP address.
You have an option to buy static IP address or use special services just call to your ISP for more detail consultation.
08/29/2008 5:50 AM
DHCP is best way to fix a ip address permanently.
Anonymous Poster (1); caramba (1); cnpower (1); Frank787 (1)
You might be interested in: IP Cores, NEMA and IP Enclosures, VoIP and IP Telephony
