Previous in Forum: Viability of natural gas conversions on cars and boilers.   Next in Forum: A new choice for president
monitor screen flickers
08/28/2008 11:53 PM
Whenever I switch on my computer and if I connect it to Numeric make UPS of 500 VA, I am observing that monitor screen is flickering. I could no able to see the display.
But if I Remove it from the UPS the I can Able to see.
Later I have remved the Erthing pin of the plug of UPS and given supply to the UPS.
That time I can able to see the display. Soon I connect earthing pin of the UPS to main supply I am not able to see anything on the screen.
Is it UPS problem or monitor Pbrolem.
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: monitor screen flickers
08/29/2008 8:43 AM
It might be caused both of them, but likely it's UPS problem as its AC-DC converter has high frequency circuits. I had similar problem when ADC converter embedded to PC went crazy once PC had been feeded through UPS. Earthing, filtering couldn't help, so i simply replaced this UPS.
Location: City : Chandigarh, Country : India, Continent : Asia, Planet : Earth, Galaxy : Milky Way, Universe
08/29/2008 11:23 PM
Hi...It is not advisable to remove earthing. Simplest solution will be to move the UPS about 2 Meters away from the monitor. This will solve the problem.
Rgds
Sanjeev
Karma is Dharma
09/02/2008 3:31 PM
You may also want to try some clamp-on ferrites around the power cables and VGA signal cables. Some monitors are very sensitive to noise on Pins 13 and 14 of the HD-15 connector (H-synch and V-synch) and will re-trigger the monitor. Better designed monitors will have gating circuits that "ignore" noise spikes outside the expected pulse rate and also "look" for pulses of the expected pulse width. Most EMI tends to be impulsive (relatively short pulse width with respect to VESA standards) but inexpensive monitors will just trigger on rise instead of looking for the pulse itself.
Brave Sir Robin (1); caramba (1); chhotu1990 (1)
