i have a 2000 cavalier that won't start or crank by the key. its my aunt car the battery and starter is fine. when i go to start the car from the key there no dash or current to anything. the horn blows and it has lights. but nothing else. but you turn the key to accessories the radio plays but not in the on position. replaced the ignition switch the same problem jump the starter it will crank but won't start. it has a after market alarm sys. in it. thought that mite been the problem but they said no because they did a test to by pass it. i jump a wire from battery to back of ignition switch the car started up and run a little then shut off. the alarm people said something about possible bad ignition relay but i can't find that part anywhere or locate it on car. i also checked all fuses everything ok.
