Previous in Forum: CT   Next in Forum: pf in 3-phase.
wincc
08/31/2008 11:47 PM
what are all the other s/w s can we we use instead of wincc to communicate with IEDs?
-by vijay
United Kingdom - Member - Member
Re: wincc
09/01/2008 4:01 AM
summit
I don't really know what your trying to do since you haven't specified it in your post, but WinCC uses an integrated OPC client to communicate. Therefore you could write your own client application in VB or C++ and put whatever it is you want to do on top of that. If you aren't too hot on software the ActiveX object for OPC in VB is very simple to use. Of course you will need an opc server as well but you may be able to manage with an off the shelf one
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Good Answers: 804
Re: wincc
09/01/2008 7:23 PM
I'm a little concerned with the idea of "controlling IEDs". Improvised Explosive Devices? I certainly hope not!
Register to Reply 2 comments
