Previous in Forum: impact of operating steam turbine below the correction curve parameters   Next in Forum: Motor & Compressor
How to calculate flow of fluid?
09/01/2008 3:51 AM
Q.1. How to calculate the required flow (lpm) of water for Hearth Roll operating at
1200 Deg. celsius atmosphere for following given data:
Max. Inlet water temperature: 45 Deg celsius
Max. outlet temperature: 55 Deg celsius
I D of hearth Roll: 100 mm
Q.2. What is the relationship between pressure and flow of fluid? a. When pressure
is 100 mili bar/cm^2. b. When pressure is 1 kg/cm^2
User-tagged by 1 user
Re: How to calculate flow of fluid?
09/01/2008 8:06 AM
<...Q.2. What is the relationship between pressure and flow of fluid? a. When pressure
is 100 mili bar/cm^2. b. When pressure is 1 kg/cm^2...>
There is a relationship between pressure drop and flowrate, which is a function of the pipe length and diameter, its internal roughness, the number and type of fittings, and the fluid properties. Use the Darcy-Weisbach equation.
Good Answers: 19
09/01/2008 11:06 PM
How much heat do you want to remove? How fast do you want to remove the heat?
09/02/2008 2:56 AM
Hi!
I don't remember how to calculate the flow but I recently discovered a very good software for piping and hydraulics systems; take a look to http://www.eng-software.com/products.
Best regards
Vale79
09/02/2008 8:13 AM
Q1. I can not answer. Because you need to know how fast you want to cool it.
Q2. Water is usually considered incompressable until it (turns to steam).
jrpeck (1); PWSlack (1); Ried (1); vale79 (1)
